94 ex cruise control
Old Apr 30, 2013 | 11:15 AM
94exvtec's Avatar
Default 94 ex cruise control
Ok, I've looked on here and I haven't found a thread for this. My cruise control does not work at all on the car. I've had this problem since I bought the car so I'm out of ideas as to what to do. I've replaced the cc module, the fuse, and the vacuum lines going to the cruise. The only thing I haven't replaced are the buttons on the steering wheel. If anybody has had this problem any help will be greatly appreciated. Thank you.
Old Apr 30, 2013 | 11:18 AM
NZXTInerTia's Avatar
Default Re: 94 ex cruise control
Does your horn work?
Old Apr 30, 2013 | 11:52 AM
94exvtec's Avatar
Yes my horn work.
Old Apr 30, 2013 | 01:21 PM
charliccs's Avatar
when you push the cruise switch near the sunroof the green light turn on in the same switch?
Old Apr 30, 2013 | 07:16 PM
94exvtec's Avatar
Yes it does, and when I activate it on the steering wheel nothing happens.
Old May 1, 2013 | 05:22 AM
Well if your horn work it kinda eliminates the clock spring being bad. You could try replacing that anyways. Do you have an SRS light? Perhaps your CC computer is fried or a wire/plug was damaged on it.
Old May 1, 2013 | 10:53 AM
djkurious's Avatar
I had the same issue a while ago. Check the cruise switch at the pedal and see if it is making contact with the pedal.
Also check out this thread: https://honda-tech.com/forums/honda-accord-1990-2002-2/cruise-control-help-94-97-accord-2466469/
Old May 2, 2013 | 11:38 AM
94exvtec's Avatar
After all the things I've replaced on my car trying to fix my cc, it turned out to be a lousy $3.00 part! The previous owner had put a bolt in the hole to get the brake lights to shut off! $3.00 part damn! On the bright side, my cc works! Thanks guys for all of your input on the matter.
bleedblue94
Jun 21, 2009 08:48 AM
bleedblue94
Jun 20, 2009 10:39 PM
Thorgs
Apr 15, 2008 12:14 PM
ophdehEEzY
Jun 26, 2003 05:12 AM
