Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
New Brakes and Rotors Scraping
Old Apr 30, 2013 | 09:40 AM
melrferguson's Avatar
Default New Brakes and Rotors Scraping
I just had new ceramic disc brakes and new rotors put on my 2006 Honda Civic. I bought the parts from Auto Zone, and had a neighbor (who is a Honda mechanic) put them on. Now there is a contstant scraping sound whether the brakes or applied or not. The mechanic said the rotors were a little big for the car and not made to Honda's specifications. He said that they normal driving would wear the rotors down and the noise would go away. Is this going to mess up my car? Are there any safety concerns I should be aware of? The brakes work fine, but the noise makes me very nervous. I hear it more during turns while driving and it's off and on while riding in a straight line down the road.
Old Apr 30, 2013 | 12:21 PM
HRsi-dan's Avatar
Default Re: New Brakes and Rotors Scraping
Do you have an Si model or one of the others? Did you get the right rotors?
Old May 1, 2013 | 09:07 AM
BurntBisquit763's Avatar
Check the backing plate, it might be bent and touching the rotor, check to see maybe a rock dirt or anything is caught up there. If its the backing plate just bend it back and it should be fine
Old May 1, 2013 | 09:09 AM
If not order the rotors that are meant for your car
Old May 6, 2013 | 03:28 AM
I had Auto Zone double check the parts they gave me and they assured me they were the correct parts. I'm taking it to Meineke this morning to get it checked. I've driven 800 miles since I had them put on and the noise is still there. I will update what I find out. Thanks for all of your help.
Old May 22, 2013 | 06:13 AM
integra15's Avatar
The pads could be stuck in the brackets to tightly. Sometimes the pads are a little out of speck and to tight, in which case you can grind off some of the excess metal or paint so they move freely within the bracket.
Old May 22, 2013 | 07:18 AM
DaveSi677's Avatar
I'm curious to see what the issue is!
blakcivicsi
Acura TL, RL & ZDX
Sep 11, 2017 08:59 AM
SuperSlow
Honda Civic (2001 - 2005)
22
Jul 27, 2007 09:40 PM
LoseRPunKx182
Jul 17, 2005 08:52 PM
TIRENECK
Jan 27, 2004 03:12 PM
Agamemnon
Dec 11, 2001 11:58 AM
