Accord won't start help!!!
Ok Here's The Thing. My Original Motor Locked Up And I Had A Spare Motor At My house So I Went On And did The Swap. Everything Went Well Until I Went To Start The Car.I Have a 96 Accord And The Motor Was Obd1. So I Did The Oil Pump Swap To Put The Cps On The Car Because On The Obd1 Motor The Cps Is In The distributor (Done This Swap Before). I Used My Obd2 Dizzy And The Car Would Crank But Not Start. There Was A Slight Leak ThAt Lead Oil Into The Dizzy Itself So I Cleaned It Out Because I Knew Its The seals. Still Didn't Start. I Checked The Fuel Rail It Seems The Pressure Is Low So I Went To The Fuel Pump But It Looks Like It Didn't Have Power But I Figured Out It Needs ground.The third Sparkplug Spot Seems To Have A Stripped Threading So It Let's Out A Lil Air. Doubt That's The Problem.I Connected It All I've Done The Specific Swap Before SO Yea.
bdubnyc
15
Mar 5, 2008 09:00 AM
crxlex
Jan 24, 2008 07:22 AM
civicrtype
Feb 26, 2003 04:22 PM
