2000 accord wper motor/traans replacement
Old Apr 30, 2013 | 07:29 AM
VeeSykkz's Avatar
Default 2000 accord wper motor/traans replacement
My manager has a 2000 accord SE and his wipers keep going off the edge of the windshield and often get stuck upright. I assume its the wiper trans, I can move them several inches by hand at the bottom. May as well do a motor trans combo. Doesnt seem hard. What should I watch out for?
Old Apr 30, 2013 | 08:48 AM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 2000 accord wper motor/traans replacement
If it is sloppy/stripped out gears, and not misaligned wiper arms, you will want to verify that the new wiper motor is in the 'parked' position prior to installing the linkage.
Connect the electrical connector up to the new motor and turn the wipers 'on' and then 'off' to park the motor. This will place the motor in the correct 'parked' position to align the linkage up correctly.
Old Apr 30, 2013 | 12:23 PM
VeeSykkz's Avatar
Pretty sure its worn. They park fine but swing wide. He even put on a shorter blade and it still gets stuck out.
batawfic
Oct 31, 2017 05:38 PM
GPC91
Jan 5, 2012 05:02 PM
97jdmek
Apr 14, 2005 04:09 PM
tspkenneth
Acura TSX
Mar 25, 2004 10:09 PM
