catalytic converter issue
Old Apr 30, 2013 | 06:46 AM
nyctrack's Avatar
Default catalytic converter issue
gonna be a generic post, cause I still need to find out specifics, but a friend of mine bought a late 90's civic, had exchaust work done, stock mind you, and then it starting throwing check engine light, later found out it was a california car and had 49 state exhaust system installed not knowing so, is there anyway to work around this without out changing exhaust system again, he's located in NJ where inspection is extremely hard to get around
Old Apr 30, 2013 | 08:40 AM
grumblemarc's Avatar
The Grumpiest
Default Re: catalytic converter issue
Then the answer would be no. But if California is the 50th state, with NJ being counted among those other 49, why would it be a problem in New Jersey?
Old Apr 30, 2013 | 11:11 PM
nyctrack's Avatar
the cat converter is Ka, 49 st, the car is a Kl, california car, so it throws a check engine light because of the mis-match, trying to figure out if the is a way to trick computer that everything is copacetic
Old May 1, 2013 | 02:59 AM
The Grumpiest
New info for me. I'm still going to stick with my original answer and say no.
Khalfani
Aug 8, 2015 02:33 PM
Fishprod
Aug 20, 2010 08:06 PM
tucktow
Oct 5, 2007 02:21 PM
Narin
Jul 31, 2004 08:53 PM
maharashii
10
Nov 17, 2002 09:00 PM
