EG turbo K-series partout
I'm parting out my car and getting out of the honda game. Here are a few parts that I'm looking to sell. The setup put down over 700hp @ 32lbs.
1) Longblock is an 86.5mm K20A2 CP 9:1 pistons, Eagle rods. Stock port head with Supertech valvetrain. Engine was built using all new oil/water pumps, timing chain/guides and tensioner. All honda parts. Less than 200 miles on everything as it was in my drag car that was down with broken trannys most of the time. This is a complete long block, valve cover to oil pan. SOLD!
2) Complete custom turbo kit. Was on my eg but will fit just about any honda/acura. Will include everything in the pic. Turbo is a Garrett Gt4294r. Kit will also include the custom intake mani w/75mm edelbrock throttle body. This is a quality, well put together kit that can make a lot of power. I will answer any questions about the kit, just ask. $3200
3) Karcepts shifter box mount. SOLD
4) Karcepts alternator relocation kit (comes with a new pulley and belt) SOLD
5) Hasport egk1 mounts. Trans bracket was trimmed slightly for charge pipe clearance. Comes with 80a and solid inserts. SOLD
6) Hybrid Racing conversion harness. SOLD
7) 4" aluminum exhaust. Vibrant muffler with polished turn-down. Fits over axle nicely and is all v-banded. $450 obo
8) T1 catch can. 2 -12 on top, 2 -10 on side, and a -10 drain. Comes with the lines and 2 -12 weld fittings (drain fitting was damaged, so I drilled and tapped for a new fitting) SOLD
9) 13x9 Weld Import Magnums (black and polished centers) with 24.5x9/13 slicks. 5 passes total. I can provide pics. $800
*** also have axles, int. shaft, alternator, and starter***
If you're intersted in anything or have any questions call/text 412-three02-one206
Everything is located in Pittsburgh, PA. I'm willing to drive to meet up on the bigger items. I'm willing to make a deal if you want to buy the engine and turbo kit together. Or will make a killer deal if you buy everything.
I have some more of it off. I'll have to check my camera to see if there's any on there of it on the car. pm me your email or phone # and I'll send them to you.
slvrslepr
Dec 23, 2010 02:05 AM
DisturbedK24
Dec 5, 2009 07:53 AM
94jrscgsr
Jul 10, 2004 02:49 PM
