Spark plug wire connections on distributor?
Old Apr 29, 2013 | 04:53 PM
ZillaG's Avatar
Icon2 Spark plug wire connections on distributor?
95 Accord EX 4cy VTEC.
Haynes manual shows connection as, looking at distributor from right side of car, 1=right, 2=bottom, 3=left, 4=top, clockwise. However, whoever put them now, has them at 1=left, 2=bottom, 3=top, 4=right - totally different of course. Which is the correct one?
I just bought NGK sparks and wires and want to do this correctly.
Old Apr 29, 2013 | 06:23 PM
holmesnmanny's Avatar
Default Re: Spark plug wire connections on distributor?
the firing order is 1 3 4 2 in a clockwise motion looking from passenger side of car(distributor facing)..so the latter appear to be correct....replace each wire one at a time to be sure you don't mess it up.
Old Apr 30, 2013 | 04:28 AM
GhostAccord's Avatar
x2
Pull one plug and wire at a time. Match one of the new wires with the length of the old wire and put it in place before removing any of the other wires. Continue until you have replaced all 4. Easiest way to do it without issue.
Old Apr 30, 2013 | 09:24 AM
MAD_MIKE's Avatar
MM Gruppe B
Haynes/Chilton manuals show the incorrect positions for the distributor cap.
Old Apr 30, 2013 | 11:07 AM
94exvtec's Avatar
Oh snap! Thats very good to know. I wasgoing to replace my wires later on today.
Old Apr 30, 2013 | 12:54 PM
ZillaG's Avatar
Yes, I did replace wires one-at-a-time. At least the Haynes manual says that. I believe the manual is correct too, I just had to find the "A" designation for plug 1, and it corroborated the 1-3-4-2 firing order.
Radim
Jun 16, 2008 04:10 PM
urtz
Nov 29, 2006 07:28 PM
VTcivicEG
Sep 1, 2004 01:13 PM
93SSPHatch
Nov 10, 2002 01:50 PM
