b18a1/eg hatch - power loss, misfire, backfiring
Old Apr 29, 2013 | 04:27 PM
Anythingbtcivic's Avatar
Default b18a1/eg hatch - power loss, misfire, backfiring
ok guys I have a b18a1 swap in my hatch and im getting a big power losse in low rps and a huge misfire when down shifting misfire and idle back fireing but my car starts good and will run but run like crap
help plz if you can heres things I have done
new plugs wires cap and rotor
new dizzy
new fuel pump and filter
new ecu
I have 2 check mtor codes there
15 and 41
15 I cant seem to get a good ex. for
41 I no the o2 is bad
my old accord had a bad o2 and it made the car stumble and sput like crazy not sure if that's is my problem
and have any advice?
Old Apr 29, 2013 | 05:20 PM
B_Swapped93's Avatar
Default Re: need help b18a1 in a eg hatch
Yes...replace that o2 unless you'r ECU is chipped and runs constant open loop(with a good fuel map) it could very well be causing what you are describing. then check you'r ign timing 15 i can't find much on either
Old Apr 29, 2013 | 05:32 PM
civicguy395's Avatar
code 15 is ignition output signal the signal going to the icm might have something not plugged in good at the dizzy
Old Apr 29, 2013 | 05:35 PM
http://imageshack.us/f/292/code150pw.jpg/
Old Apr 29, 2013 | 05:37 PM
also
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/htf-do-you-fix-code-15-a-1656532/
Old Apr 30, 2013 | 05:44 AM
I put a brand new dizzy from Honda on the car still same code
Old Apr 30, 2013 | 06:30 AM
sleepyaccord96's Avatar
Default Re: b18a1/eg hatch - power loss, misfire, backfiring
are your spark plug wires in the correct order?? 1 3 4 2
jrhcivak
Jun 18, 2012 12:38 PM
yo bj
15
Apr 18, 2012 06:22 AM
ef8b16a1
Feb 15, 2006 05:01 PM
frogscivic
Jan 17, 2004 06:14 PM
SleepnCiViC
18
Dec 8, 2003 08:51 AM
