Transmission & Drivetrain Gearboxes, Differentials, Clutches
Honda S80 gearbox after market lsd kaaz??
Old Apr 29, 2013 | 02:59 PM
fire_king's Avatar
Default Honda S80 gearbox after market lsd kaaz??
Hi just wanted to ask is there a way to see what lsd is fitted in the box other then pulling it Apart I was told its a kaaz lsd. I driven the car before removing the box myself and LSD was very strong in corners
Here's a few pics. I no on the oem LSDs you can see straight through the shaft hole this one is the same but looks like it has a smaller washer/bearing in it as well
Thanks in advance.
Old Apr 29, 2013 | 03:25 PM
94EG8's Avatar
Seagull Management
Default Re: Honda S80 gearbox after market lsd kaaz??
I know OBX had that small hole, I'm not sure about Kaaz.
Old Apr 29, 2013 | 03:56 PM
fire_king's Avatar
Thanks for the reply searching on google kaaz LSDs are also like that when looking in the shaft hole goes from big to small then big again its like a washer. Will see what others think if not might just pull it apart. But I was assured it was a kaaz diff
The hole on this looks the same
http://www.frsport.com/KAAZ-DBH1822-...91_p_8581.html
Old May 5, 2013 | 06:02 PM
f20b jones's Avatar
obx and kaaz look like that . Ive had good luck with both but my kaa seemed more aggresive actually dragginf a tire if turned real sharp. If you can tell its pulling in corners probably a kaaz. Ive never had a obx feel that aggresive.
defensio
May 10, 2010 04:20 PM
HondaPH22
Nov 23, 2006 12:52 AM
SINISTR
Nov 16, 2006 04:42 PM
John
Oct 20, 2001 03:54 AM
