Mid-Atlantic (Sales) VA, DC, and MD
MD SC50 Precision turbo, 72lb injectors, Tial, BOV, Q45, etc
Old Apr 29, 2013 | 07:21 AM
Purple-skunk's Avatar
Default MD SC50 Precision turbo, 72lb injectors, Tial, BOV, Q45, etc
Part: MSD 72lb injectors and resistors (disclaimer:resistors off a SR20DE, so not certain if it will work with a HONDA)
Means of contact: PM/email
Price: $ 250 OBO
Description:
Hello
I have a set of MSD 72lbs injectors with compatible/correct resistors for sale. I was going to use these, but ended up going with a standalone and custom pigtails for the injectors, so this is not needed. They are in good condition and have less than 2000 miles on them, so they are in fantastic condition. Part number for the MSDs are in the picture set below
Thanks much!
Pictures:
IMAGE:
Part: Z32 MAF (N62)
Price: $ 85 OBO
Description:
Hello
I have a very good condition Z32/N62 MAF. Mesh Screen is in good condition as well as the hot wire element. Sensor has NEVER been apart!
NOTE: NO PIPING, COUPLERS OR ANY OTHER PART APART FROM THE MAF IN THE PICTURES ARE INCLUDED!
Thanks much!
Pictures:
IMAGE:
Part: Tial 38mm Wastegate
Wastegate sold!
Part: Precision SC50 Turbo
Price: $ 500 OBO
Description:
Hello
I have a very good condition GENUINE Precision SC50 460 HP turbo for sale. In and out shaft lay is nonexistent. Radial shaft play is minimal at best (and as everyone knows, every single journal bearing turbo has a minor amount of shaft play and as oil pressure is seen, the clearance tightens up and so does the radial shaft movement). Mileage on this turbo is circa 2000 miles and is ceramic coated (the coating alone is 150 dollars). The turbo new, the lowest I have seen, is $829.79 dollars. Now, with ceramic coating, you are looking at over $1000 with shipping and such NEW. The turbo comes with a 360-degree race bearing center section and a T04E compressor cover with a 3-inch inlet and 2-inch outlet. The trim however, I am not certain of. PRICE IS OBO!
Turbine A/R: 0.63 (5 bolt housing)
Compressor A/R: 0.60
Part number on Turbine housing:
Thanks much!
IMAGE:
Part: Q45 TB with TPS sensor
Price: $ 120 OBO
Description:
Hello
I have a very good condition Q45 TB with original Nissan TPS sensor (fairly a pain to find). All linkages work and is in good working condition
Thanks much
IMAGE:
Part: DSM 2G Plastic BOV
Price: $ 20
Description:
Hello
I have a DSM 2G plastic BOV with unknown miles. Looks to be in good condition
Thanks much
IMAGE:
Part: T3 Center section Oil Drain Aluminum Adapter
Price: $ 20
Description:
Hello
I have a great condition T3 center section Oil Drain Adapter. Comes with Hose and hex nuts
Thanks much
IMAGE:
Old May 1, 2013 | 07:57 AM
Default Re: MD SC50 Precision turbo, 72lb injectors, Tial, BOV, Q45, etc
Wastegate sold!
Old May 6, 2013 | 03:06 AM
Bump
Old May 12, 2013 | 03:43 PM
Bump!!!!!!
Old May 16, 2013 | 08:58 PM
Bump!!!!!!!!!
Old May 18, 2013 | 05:50 AM
Injectors sold!!
Bump!
Purple-skunk
May 24, 2013 06:22 AM
tremor86
May 15, 2013 08:28 PM
