5 speed trans
Old Apr 28, 2013 | 07:00 PM
willmrush's Avatar
Default 5 speed trans
I have a 1995 Accord F22b1 with a 5 speed. I was looking under it and its covered in oil (Gear oil?) it flows down from the top of the trans. My best guess is this nipple I found with no hose connected(see picture). I have no idea what this nipple is for and did not see any hoses around it or near by.
Old Apr 28, 2013 | 08:10 PM
92 civic ex 4dr's Avatar
It's a breather. Shouldn't have fluid coming out of it unless the Trans is somehow overheating???? Or it was over filled somehow our your jumping your car.
Posted from Honda-tech.com App for Android
Old Apr 28, 2013 | 09:36 PM
willmrush's Avatar
Default Re: 5 speed trans
Ok thats what I thought I see oil down in it. The car has not been jumped and I myself have never touched the fluid. I'll check the oil level tomorrow.
Old Apr 29, 2013 | 12:53 AM
holmesnmanny's Avatar
That nipple is supposed to have a rubber cap on it. You should get one when you get a chance.
Old Apr 29, 2013 | 06:51 AM
sleepyaccord96's Avatar
i see the shifter cable isn't hooked up...did you just replace the trans or clutch
Old Apr 29, 2013 | 05:08 PM
willmrush's Avatar
That is the mount for the OEM airbox.
Old Apr 29, 2013 | 05:09 PM
willmrush's Avatar
I will do that. Since it has not had one would that let the oil blow out?
Old Apr 29, 2013 | 05:59 PM
GhostAccord's Avatar
It should not be completely sealed. If you put a solid cap on it, it will usually pop off as the trans heats up. Probably why it's not there now. It should have a rubber breather type cap. You could get a solid cap and cut a slice in the side of it to allow it to breathe.
Or buy a new OEM breather cap. Part number 21396-PX5-000 - Cap, Breather
If the oil is coming from the top of the engine. It could be your distributor seal or valve cover gasket.
Old Apr 30, 2013 | 05:14 AM
willmrush's Avatar
Ill buy the right cap and get that done. My distributor seal is next on the list I know its leaking a little bit. Thanks for the info.
renzis00
15
Sep 26, 2012 10:18 PM
shoklid
May 6, 2010 08:31 AM
TMC_EF
Dec 13, 2007 05:44 PM
Tonyl507
Dec 8, 2006 09:32 AM
OldMrAccord
Jun 27, 2005 12:46 PM
