Prelude Windage tray in 91 accord?
Old Apr 28, 2013 | 04:17 PM
Mishako129's Avatar
Default Prelude Windage tray in 91 accord?
Will this work in my LX? I picked this off a junkyard 95' lude,
Old Apr 28, 2013 | 04:38 PM
GhostAccord's Avatar
Default Re: Prelude Windage tray in 91 accord?
They are the exact same part number as the ones used in the F22A* block. So short answer yes. You know you should really try using the readily available parts microfiche for parts cross referencing.
Use sites like Hondapartsdeals.com to cross reference parts like this. It's amazing what you can find out when using part numbers. Take the part from one car, for example your windage tray, aka baffle plate, under the make model and year of the car you took it from. Find the number for said part. Then cross reference it with other cars to see if the part numbers match. Now in saying this your block did not come with a windage tray. However other models that use the same block did. Therefore the baffle plate will fit.
It can get confusing but once you learn to cross reference parts it makes building hybrid engines much easier. You gotta start somewhere and a parts microfiche is a good place to learn.
Old Apr 29, 2013 | 10:59 AM
NZXTInerTia's Avatar
Do you never EVER listen to us? Check a parts website like Ghost said, and myself and many others have suggested..
Old Apr 29, 2013 | 11:12 AM
Mishako129's Avatar
I didn't think of that, probably because sometimes I have trouble finding the part in the catalog. Will take you seriously this time though.
LatnKng
Nov 23, 2011 03:14 PM
lowandslowcb7
Nov 12, 2009 08:41 PM
Eyabusa
Jan 15, 2005 06:36 AM
