Complete GSR Rebuild
$1500 to $2000 TOTAL BUDGET!!!!!!!! NO POWER ADDERS (NOS, TURBO, Supercharger)!!!!!!! COMPLETE REBUILD on a 170,000 mile USDM GSR...
Already have a Hytech header, Skunk2 IM, 70mm TB
Need to replace the valves (bent after a horrible mis-shift)...
Where would you spend your money to make extra horsepower????????
Good cams/valve train
Itr pistons
Arp head studs
New gaskets oil pump/water pump
S300 and tune
That should make you some good hp for not a huge nut to the pockets.
One of my engines was setup similar and in my Ef hatch went 13.0 at the strip with slicks with some room for improvement then I started spraying nitrous before getting it to go faster na.
Itr pistons
Arp head studs
S300 and tune
ITR or CTR pistons on the GSR rods was a thought...
thinking of a combination of Supertech, Blox, and Brian Crower for the valve train..
ARP head studs is worth the $125.00
New gaskets, seals, oil and water pumps are a definite!!!
Thoughts on "good cams"?????
Read the FAQ. Educate yourself.
This is a tech discussion forum, not a "build my setup for me" forum.
Once you do some reading and have specific questions then by all means post. But don't expect people to spoon feed you information here.
AnT PERFORMANCE
Aug 5, 2011 06:06 PM
