off timing by a tooth
Old Apr 27, 2013 | 10:31 PM
mysuperslowej1's Avatar
Default off timing by a tooth
i'm having a real funny idle cold idles are a between 200-800 after it warms up 800-1100, i'm not running bad or anything no cel's running pretty lean though. just a stock z6 with y8 IM, if i'm in time what could be causeing this? i've adjusted my idle speed a couple of times with no success.
Edit:
i changed my spark plugs, changed fuel filter, cleaned iacv, changed oil.
Old Apr 28, 2013 | 12:23 AM
Cjlarson14's Avatar
Default Re: off timing by a tooth
Still need to state the vehicle your talking about otherwise its up in the air. Check your timing, clean Iacv, bleed coolant system for any air in the system, and adjust idle screw. Be a good start. If you've done any of these then cross them off and try the next one.
Old Apr 28, 2013 | 07:35 AM
yeah I've done all of these except check my timing. And I'm in a eg coupe.
Old Apr 28, 2013 | 02:36 PM
Cjlarson14's Avatar
Have you checked your FICV (Fast Idle Control Valve)? I've had a buddy do something similar to what your stating and that's what it ended up being after doing just about everything else. ALSO.... Check your timing.
Old Apr 28, 2013 | 07:23 PM
yeah actually just rebuilt it about a month ago. well I wouldn't really call it a rebuild but either way yeah that should be fine. guess ill go ahead and check my timing. hypothetically if its fine what else should I check for something like this?
carlos8
Sep 16, 2016 11:17 AM
jdmtegrunner
Oct 18, 2009 11:30 PM
kornerk12
Apr 13, 2009 05:33 PM
NoVALude
Nov 20, 2006 11:02 AM
ogwutang
May 5, 2003 05:36 PM
