96 GSR Headers
Which of these bolt up to the factory exhaust? I almost always hear that the 96-97 GSR exhaust is "short" and i'll need "custom piping" to make it fit. Surely someone has made a drop in replacement?
there is NOTHING special about the 96-97 gsr model i don't know who told you that...94-99 are All the same there is however a slight difference with the 00-01 hanger placemeant afaik.
http://www.clubintegra.com/board/showthread.php?t=16587
That thread contains several pictures showing the difference in length..
The 94-99 GSR had a shorter header... DC Sports even offers 2 different 4-2-1 One Piece. One for the 94-99 GSR (seen below)
http://www.andysautosport.com/acura/...p00034349.html
And one for the 00-01 GSR that APPEARS longer (matching the diagram above).
http://www.andysautosport.com/acura/...p00034350.html
If they are different lengths... then something must be done to the 94-99 GSR setup when using a "normal" B-series header that fits every other B series (since the normal B Series headers are the same length as the 00-01 GSR and all Type R's and too long for the 94-99).
