Need help wiring iat sensor!!!
Old Apr 26, 2013 | 04:02 PM
slimjim07's Avatar
Default Need help wiring iat sensor!!!
Long story short I have to pass emissions so I traded my p30 ecu for a stock p72 for my gsr swapped civic and I can't get the iat wired to it correctly. I got the wiring diagram from ffsquadtech and failed multiple times. Any help would be greatly appreciated!
Old Apr 26, 2013 | 04:09 PM
B_Swapped93's Avatar
Default Re: Need help wiring iat sensor!!!
Where is the issue...can you not find the wires ? you have to be more specific.
Old Apr 26, 2013 | 04:23 PM
slimjim07's Avatar
I've found the wires the green wire from the sensor goes to d8 on the ecu correct and which one does the ground go to?
Old Apr 26, 2013 | 04:31 PM
here:http://www.ek9.org/forum/other-techn...bd2a-obd1.html
Old Apr 26, 2013 | 04:44 PM
slimjim07's Avatar
That's the same exact diagram I have. I wired the black from the sensor to d11 and d13 but it isn't working
Old Apr 26, 2013 | 05:02 PM
HondaPartsHero's Avatar
Technical Hero
What year is your car and ecu you are using?
Old Apr 26, 2013 | 05:21 PM
slimjim07's Avatar
97 ex and p72a04
Mik3o
Feb 26, 2015 02:53 PM
MOVE OVER
Dec 29, 2005 10:33 PM
