Popping Noise from steering wheel/column when turning side to side
Old Apr 26, 2013 | 08:10 AM
dth0ng69's Avatar
Default Popping Noise from steering wheel/column when turning side to side
I got a 96 Civic Hatchback dx no powersteering, I don't know if I noticed this before installing my new Steering wheel set up.
But after I installed my steering wheel I noticed that When I turn right or left while the car is still or going really slow it will make a pop noise. If i was on a stand still with steering wheel straight, and jerk the wheel right it make that noise, jerk back left it will make that noise. Its like a single pop noise and sounds like its coming from the steering column, but i'm not too sure.
It doesn't happen when I'm rolling past 5 miles per hour, everything seems to drive and steer fine. this single pop noise happens only when I'm stopped, or very close to be being stopped.
I've done some reading and I heard axles (it can't be because i'm not turning all the way)
I heard tie rods, and upper or lower ball joints. and even worst I heard (steering rack assembly etc) omg please no.
Any one here have any experience with this ? if so please share
thank you for reading
Old May 3, 2016 | 09:54 AM
slomofo's Avatar
GDD Member
Default Re: Popping Noise from steering wheel/column when turning side to side
Are your rack bushings good?
crxbrad
Jan 31, 2014 05:36 PM
swizz977
Aug 31, 2010 06:30 AM
pr0phet
Oct 17, 2005 08:24 PM
B16Civic93
Dec 21, 2004 08:23 AM
nightrider
Apr 6, 2003 01:10 PM
