1996 Accord EX 2.2 EGR question
Old Apr 26, 2013 | 04:14 AM
wrichey1's Avatar
Default 1996 Accord EX 2.2 EGR question
My daughter's car has had an EGR code for over a year. I finally had the ports and valve cleaned and now the car will start and idle fine but once you drive it down the road and come to a stop it will not idle and when it stalls it is hard to restart and will not idle. If I pull the egr vacuum line after it stalls. which is still under vacuum, the car will start right up and idle again (until driven).
Is it the egr vacuum control solenoid or the egr vacuum valve that would cause this? I think the egr valve is ok as it seems to hold a vacuum and opens and closes freely.
Thanks in advance!
Old Apr 28, 2013 | 04:54 AM
Lost Again's Avatar
Default Re: 1996 Accord EX 2.2 EGR question
I wouldn't throw parts at the problem until you know what the issue is.
Need to test a few things, yes based upon your description - testing the solenoid would be a place to start.
BuddhaSiR
Feb 16, 2007 04:51 AM
1990AccordEX
Oct 1, 2005 06:23 AM
syshackmin
Jul 5, 2005 11:57 AM
bathanr
Jun 29, 2005 06:50 PM
b18cvtec
Jul 16, 2003 04:16 PM
