Lots of Single Cam Parts
Located In Milton Wa
All Prices are pretty firm, but give me a PM
Crank Pulley (2 Z6's and 1 A6 w/rubber) $30 each
Z6 Alternator Belt 5k Miles $10
Y7 Alternator Belt (Y7 is a little longer than Z6) 30k Miles $5
D16Y7 1996 OBD2a Alternator w/ Pigtail $40
D16Y7 1996 OBD2a Distributor $50
D16Z6 Transmission Housing Dust Shield $10
Stock Map Sensor $10
Stock TPS Sensor (Tip cracked but it works) $5
Stock IAT Sensor (Cracked but it works) $5
OBD2A D16Y7 5 Speed ECU $40
Lower Timing Gear w/ Belt Guides $10
Transmission Lower Rad Hose Bracket $5
Coolant Pipe (Specify Style) 5$
Thermostat Housing $10
Stock Jack $10
Engine Mounts/Brackets (Specify) $10
EF Headlight Switch and dash dimmer and defroster switch $5
EK armrest (Pickup only) $30
EG AC Wire Harness Uncut $10
Balanced and Resurfaced D Series Flywheel (If I don't use it first) $50
New Valve Stem Seals (8) $5
New Thrust Washers $2
Z6 Throttle Cable Bracket $5
D16Y7 Throttle Cable $5
Alternator Power Wire $5
Alternator Tensioner $5
Alternator Mount $5
Reverse Light Switch $5
Spark Plug Wire Bracket $5
ECT Sensor $10
Water Temp Sending Unit $5
Oil Pressure Sender $5
Complete Y7 Intake Manifold $50
Strange Alternator OEM disconnect (left of the jack) $5
JDM B-Series Alternator w/ pigtails and brackets $50
JDM B-Series Intake Manifold w/rail regulator IACV $60
Cut and Media blasted DOHC Vtec Cover w/cap $50
JDM VTEC B16A Cams $50
New Omnipower 68mm TB $80
Battery Terminals $5
Fresh Cleaned D16Z6 Bare Block Mains Checked at machine shop and they said it's good to go! Stock Bore $60
D15B2 Head rebuilt 30K ago! $80
Full Rear Interior out of 96 DX Coupe Charcoal Grey Ask for Parts!
If You need anything else feel free to ask!
If you need any metric bolts, let me know the head size and approximate length. I have all kinds of stuff!!
PM me!
Edit: Woops Can I get this moved to the NW section
Stock Jack $10
Alternator Mount $5
ECT Sensor $10
PM me!
Aquafina
Sep 25, 2007 06:55 PM
