Transmission & Drivetrain Gearboxes, Differentials, Clutches
Is putting a front gasket seal going to be worth the trouble?
Old Apr 25, 2013 | 06:41 PM
mnbrant's Avatar
Default Is putting a front gasket seal going to be worth the trouble?
I noticed some leaks under my 1994 honda accord ex. They fixed the oil leaks but some transmission fluid is leaking from the right front gasket seal. They said that they weren't going to fix it because it the transmission is probably damaged and it would soon start leaking again. I went to the O'Reilly parts store and they said the job takes two hours and the shop I went to didn't want to do it. (The shop told me to start looking around for a used transmission. What one is right? From what I have been reading the mechanic shop is probably right. Also what kind of automatic transmissions would fit in a 1994 honda accord ex? I am seeing them for the 200-300 dollar range on craigslist.
Old Apr 26, 2013 | 05:45 AM
94CivicSi's Avatar
Default Re: Is putting a front gasket seal going to be worth the trouble?
Do you mean the axle seal? They're only around $8 each.
Old Apr 26, 2013 | 06:18 PM
mnbrant's Avatar
hmm they were 32 bucks at O'Reillys and are supposed to take a few hours to put in. The problem is that the owner of the garage I go to says that it wont fix the problem because they fail due to a problem with the transmission
Old Apr 27, 2013 | 06:24 AM
94EG8's Avatar
Seagull Management
Front trans seal/input shaft seal perhaps? If that's the case and there is a burr on the input shaft yes it will leak again. Similarly if it's an axle seal and there's a burr on the axle, or if a differential bearing is bad it will continue to tear up seals.
keving58
Jan 11, 2011 08:06 PM
sillyboi
Nov 5, 2010 07:58 AM
Hondamatic-s
Classic Hondas
Feb 19, 2010 01:49 PM
