acura integra code p0441
Old Apr 25, 2013 | 10:11 AM
billyinse's Avatar
Default acura integra code p0441
alright so i have a99 acura integra gs( auto) and i put in a 98 5 speed gsr swap. the motor has been throwing this code(po441) since i swapped it in. i just replaced the solenoid on top of the intake manifold and the charcoal canister the CEL still came back on.
i am wondering if the wiring may be wrong due to the swap? or if there is something else i can check?
Old Apr 25, 2013 | 12:13 PM
B_Swapped93's Avatar
Default Re: acura integra code p0441
Did you re-set the ecu ? the swap shouldn't have affected it. unless you mixed up something.(wires)
Old Apr 25, 2013 | 03:17 PM
billyinse's Avatar
yes i reset the ecu. as for wiring that is what i am wondering, was i supposed to re pin anything for the evap system?
Old Apr 25, 2013 | 03:33 PM
Have you considred an obd2 to obd1 jumper may get rid of it. i just ended up ripping my evap sys out
here's the pinout sheets i've used:
http://technet.ff-squad.com/wiring.obd1.htm
http://www.ek9.org/forum/other-techn...bd2a-obd1.html
Old May 17, 2013 | 07:51 PM
billyinse's Avatar
i ordered an obd1 ecu and a jumper harness. we will see what happens.
portablenarc
Aug 23, 2014 07:14 AM
Evoknight10
Engine Management and Tuning
Jul 30, 2012 04:12 AM
frankie-jay
May 3, 2007 03:49 PM
