Strange Injector #1 issue need electrical experts !
I have a really odd electrical issue with my #1 injector. it will be out(no signal at ecu/ecm)most of the time but will come back evey so often when it's on it pulses like it should and is getting a steady signal at the ECU/ECM. but when it's out it will still sometimes a get signal at the ecu but nothing at the injector end. it's not the injector it's self i've swapped them all around several times still remains at #1.
have done pulse test(when it works)pulses as it should, have used test light to check signal at the ECU all other injectors have steady signal even #1 some times. Car is a OBD1 GS-R.
you can see when i plug it(injector clip) back in it comes back on randomly
Its possible the ground is bad. When you put the lite to it it acts like its shorted before it gets to the injector. If you do it to the other wire in the plug do you get the same symptoms or does it get better.
@mr beeks will an obd1 pig tail(s) from a civic or DSM work AFAIK we can use dsm(obd1) injectors on our cars not that im intrested in the injectors more so the pigtail
Grounding issue ? but it comes back....that's only a temporary fix should i replace the pig tails as the issue seems to be on the "engine" side of the harness rather than the ecu that being said when i tested the wires at the ecu it would do the samething" kill the injector"
Chickenjoe757
Jan 9, 2018 03:30 AM
glenb902
Jan 4, 2016 05:45 PM
lsvtek
15
Jul 10, 2012 02:28 PM
mickey b16
May 18, 2009 07:33 PM
SweetDA9_TR
19
Mar 18, 2009 08:10 AM
