rdx injectors on b series! need help!
Hey guys I got some rdx injectors n I want to put them into my b series got all the clips n hats, the thing I need help on is when I put the hats on the injectors do I shave down the little plastic hook at the top so the hat sits flush/straight? I know I probably do have to but wanted to see if anyone done it themselves and can give me some feed back if it leak or works fine thanks! Any info helps!
I had these while i was testing the OBX ITBS and the OBX fuel rail cleared fine, I'll be running a sk2 comp fuel rail and i believe it will clear that fine too.
There's no need to trim the hooks off. You might have to re shim your fuel rail since the rdx injectors may cause a height difference using the "hats". Btw the hats are un necessary if you have even the slightest mechanical aptitude and some drill bits. I refused to buy the hats and drilled the rail to fit the 14mm injector top.
i also did not trim the hooks
after upgrading intake manifold i trimmed them and it made almost no difference
btw i have blue hats not green
Just received my injectors yesterday and i was wondering if everyone was using the clips that come with the adapters? Mine doesn't fit around the injector evenly.
