FS: b series transmission parts, itr lsd, gsr diff, b16 gear set, ls gear set, ls 5th
Old Apr 24, 2013 | 08:29 AM
98GSR-Turbo's Avatar
Default FS: b series transmission parts, itr lsd, gsr diff, b16 gear set, ls gear set, ls 5th
I have some b series transmission parts I need to get rid of.
95 GSR open differential w/ ring gear bolts NO bearings $100 SHIPPED
LS gear set w/ matching ring gear NEEDS synchros gears are good $200 SHIPPED
LS counter shafts with good 1-2 synchros w/ 5th gear for main shaft. Great for LS 5th gear swap. $115 SHIPPED
2x LS shift forks, shift actuator, reverse idler, and reverse fork $65 SHIPPED EACH SET
Random parts: 2x LS 3rd gears, 2x tapered cones, 3-4 gear collar, ring brake, bearing collar in tapered cone, 1.32mm differential shim, and random bolts OFFER ON ANYTHING
Old Apr 25, 2013 | 05:24 AM
Default Re: FS: b series transmission parts, itr lsd, gsr diff, b16 gear set, ls gear set, ls
Bump
Old Apr 26, 2013 | 05:36 AM
Ttt
Old Apr 27, 2013 | 04:55 AM
Bump
Old Apr 27, 2013 | 03:50 PM
spud-tech's Avatar
3x LS shift forks, shift actuator, reverse idler, and reverse fork $65 SHIPPED EACH SET. Will this set work on gsr Tranny?
Old Apr 28, 2013 | 06:45 AM
Yes it will work.
Old Apr 28, 2013 | 11:29 AM
Marvin1985's Avatar
Do you have a B series VSS? Lmk 814-651-4192 txt
Old Apr 28, 2013 | 05:22 PM
Lsd b16 gear set 1 Ls 5th set and a shift fork set sold
Old May 2, 2013 | 10:01 AM
Up
Old May 3, 2013 | 09:50 PM
Ttt
Old May 6, 2013 | 02:11 PM
slobalt716's Avatar
avoid this seller. i paid him $1000 for a transmission and these are the parts. he will not give me a refund.
Old Sep 15, 2013 | 09:05 PM
vipersal's Avatar
I need the gsr diff but mines use differents bearings.
baller status
Transmission & Drivetrain
24
Jul 6, 2016 05:56 AM
sportsman1539
Sep 8, 2014 04:39 PM
Redline4Life
Northeast (Sales)
40
Oct 10, 2010 02:49 PM
Redline4Life
Sep 27, 2010 08:01 PM
alwaystootall
Aug 23, 2009 08:53 AM
