Ek Fog light wiring question, Broken Relay Tab ?!?!?
If you've ever hooked fogs you know what I'm talking about already, I Was gunna tuck the harness so I was trying to unplug the pin from the relay and it broke off the tab? Will they still work?? Or is they anyway to get around that tab being broken idk if it has to be grounded or what ... Thanks, if you have a solution I'm open to all suggestions thank you.
Really? Unless you're not in the US. Radio shack? Home Depot/Lowes? Some auto parts stores have an electronics section.
Do you mean you just broke the mounting tab? They're not grounded through there so you shouldn't worry about it. It will still function normally.
