Eh3 hatch rear hub
Old Apr 22, 2013 | 08:31 PM
Hyunbs's Avatar
Default Eh3 hatch rear hub
Hello, im replacing my left side rear drum hub assembly and i was wondering if i should replace my left side as well? Im replacing the right side due to a stripped stud. Buying either one hub assembly for $26 or both for $40. Brand new. On sale. So all I need to know is do I have to swap them both out? I dont mind doing both.
Old Apr 22, 2013 | 09:09 PM
jbpnoman's Avatar
Default Re: Eh3 hatch rear hub
You don't have to, but considering the age of the car (and assuming the original factory units are still on the car) it wouldn't hurt to go ahead and do it as preventative maintenance.
Old Apr 22, 2013 | 11:10 PM
Hyunbs's Avatar
Thanks for the reply! Okay yeah thats what I was thinking too lol. Byw i found these on eBay for $48 for both. Are eBay parts okay? I went to autozone and they asked for $50 for one assembly. Just wondering if these will do?
http://www.ebay.com/itm/2-NEW-PREMIUM-REAR-WHEEL-HUB-BEARING-ASSEMBLY-UNITS-PAIR-SET-FOR-LEFT-AND-RIGHT-/400465557654?pt=Motors_Car_Truck_Parts_Accessories&hash=item5d3d9b7896&vxp=mtr
Old Apr 22, 2013 | 11:17 PM
jbpnoman's Avatar
Whoah, time out. Why are you replacing the entire assembly? The studs can be replaced individually, as can the bearing.
Old Apr 22, 2013 | 11:39 PM
Hyunbs's Avatar
Isnt it just easier to do so? Should I keep the original assembly?
Old Apr 23, 2013 | 12:31 AM
jbpnoman's Avatar
Easier? Maybe. Three times as costly? Definitely. If you only need to replace a stud, just replace the stud. If you need to replace the bearings, just replace the bearings. Use OEM parts, not knock-offs. OEM bearings and studs are cheap.
Old Apr 23, 2013 | 10:18 PM
Hyunbs's Avatar
Oh okok thanks so much for the heads up.
2000integrablac
Jun 4, 2017 06:43 PM
nicknack25
Feb 20, 2014 07:26 PM
ep3drvr
Apr 8, 2007 10:39 PM
