gsr tranny
what would make this happen? I was on the track first burn out and it sound like i broke a axle, well after i was inpected the car this what i found!!!! I know that stock tranny =635hp turbo car its on the limits but still looking for any one that might know what can cause this? this tranny its been good for about 3 years on stock gears 550HP only replaced 3&4 sleeve and Carbon syncros but its been i good tranny for been stock tranny lol !!!!
That failure is cause by shock load. Was this an aftermarket Final Drive? If not, I recommend a stronger aftermarket final drive or if you need OEM ratio get a set hardened. With that much power this will happen on occasion. I think there may have been a fractured tooth on the pinion, and the last burnout you did finally broke it all the way.
& gears) and how long it take it? my email svictorleon@aol.com thanks.Marco
CALC!_JUST_du_IT!
Sep 20, 2007 12:17 PM
