91 prelude si throttle issue
Old Apr 22, 2013 | 03:34 PM
crazy_ls_90's Avatar
Default 91 prelude si throttle issue
I have a 91 prelude si that i race as a dirt oval car.
The issue im having is when i put it in gear(its an automatic)and tap the throttle it acts like it sticks some. I have checked the cables and nothing is stuck.
Could it be the kick down cable on the trans or the iacv or tps?
This isnt a huge issue because i normally run it in 2nd only it just makes it hard to load on the trailer.
Thanks
Old Apr 23, 2013 | 10:37 AM
THC07's Avatar
Default Re: 91 prelude si throttle issue
maybe there is dirt in it? lol jk jk
have you cleaned your TB at all?
Old Apr 23, 2013 | 12:13 PM
Lol. I havent actually took it off and cleaned it.
I probably should though.
Old Apr 23, 2013 | 04:18 PM
THC07's Avatar
Solenoids and tranny fluid check. you can bench test the solenoids via a write up here on HT
Old Apr 23, 2013 | 05:53 PM
The trans fluid is good. Im gonna clean the tb this week and see if that helps.
Old Apr 25, 2013 | 07:34 PM
I took the iacv off and cleaned it and no more throttle issue.
dedbike
Engine Management and Tuning
Dec 17, 2013 05:23 PM
puertoricanboy90
Dec 1, 2008 08:01 AM
neoh74
Aug 12, 2004 10:43 AM
79 civic
Apr 19, 2004 05:08 AM
