b18 shift linkage bushings
The shifter bushings are under $5 each, [two of them] the thrust washers are under $4 each, [two of them] a coller if you need on is under $10, [one] the O rings are under $1 each, [four of them].
You can probably get it as a "kit" for under $30.
As mentioned, stick with OEM. 94
Sweet thanks guys. My buddy has bushing for a d16 shift linkage would those fit a b18 linkage? Cause he said he'd hook me up with em if they do fit.
8Gomer9
Aug 5, 2009 10:47 AM
