Integra K20 Swap, the right ecu ?
Old Apr 20, 2013 | 07:50 AM
Black_horse's Avatar
Default Integra K20 Swap, the right ecu ? *Solved*
Hi
I know it might seems like silly question , but I'm somewhat confuesed about
the ecus.
I'm doing K20 swap to my integra, got everything on , but the ecu, will any k20 ecu go on with it ? Or I need to match the engine code ?
I can't seems to get it right , can someone expalin to me how engines <=> ecu , are related for the k series ?
I want to buy ecu and send to install hondata chip on it. So I don't want to end getting the wrong ecu and wasting money.
I have k20a with 2PND on the label of the block.
5 spd M/T RSX base. I heared 6spd ecu will have issues with 5spd is it true ?
I just need explination, that's all.
Old Apr 20, 2013 | 11:06 AM
whitesihatch's Avatar
Default Re: Integra K20 Swap, the right ecu ?
no, any ecu within the year range will work. The usdm ecu have an immoblizer, but I believe the JDM ecu dont have an immoblizer.
Old Apr 20, 2013 | 11:43 AM
Is there a way I can tell which has immoblizer , and which not ?
And I can use any ecu even if it was for automatic ?
The reviews on the intenet got me all messed.
Thanks.
Old Apr 20, 2013 | 02:20 PM
doood's Avatar
been there done that
Any 02-04 prb or pnd manual ecu will work with kpro
http://hondata.com/kpro.html
Old Apr 21, 2013 | 02:37 AM
Ok thanks.
That was more complicated than I thought.
Still , how to know if ecu has immoblizer ? Is there a way to tell ?
Old Apr 21, 2013 | 07:40 AM
doood's Avatar
Why does it matter?
Old Apr 22, 2013 | 11:01 AM
Won't that prevent my car from starting ?
I read at other forums , either I disable it , or use ecu without immobilizer.
Old Apr 22, 2013 | 11:12 AM
doood's Avatar
Kpro let's you disable it
Old Apr 22, 2013 | 02:56 PM
Alright, Thanks Doood.
mita
Aug 28, 2014 11:46 PM
mrx
Mar 28, 2005 05:56 AM
gr8bigbox
Jun 8, 2004 09:54 PM
turbotime
Jul 14, 2003 09:54 AM
