Stupid Question But I need an answer guys PLEASE!!!!
Old Oct 22, 2002 | 07:44 PM
Proper's Avatar
Default Stupid Question But I need an answer guys PLEASE!!!!
Can someone tell me what indicator light on the cluster flashes with the beep when you start your car or put it in the "on" position? I have a 89 civic std with no tach so I'm not sure if it would be different for other models. It's a dumb Question but I'm sure you guys can help me out. Thanks in advance
Old Oct 22, 2002 | 07:50 PM
thaiphob's Avatar
Nikon!!!
Default Re: Stupid Question But I need an answer guys PLEASE!!!! (SOHC'd up)
with or without a tach all the same lights flash.
Old Oct 22, 2002 | 08:28 PM
Proper's Avatar
Default Re: Stupid Question But I need an answer guys PLEASE!!!! (thaiphob)
Ok, Is there more than one light that should flash? If so which ones? I'm trying to wire up a gsr cluster and the dummy lights all light up on the on position but for some reason the oil light flashes with the beeping noise. I think I may have hooked it up to the wrong wire. so if anyone could help it would be great
Old Oct 22, 2002 | 08:30 PM
thaiphob's Avatar
Nikon!!!
the battery,check engine and oil light should light up for like two seconds and then turn off.
Old Oct 22, 2002 | 09:17 PM
EG8R's Avatar
You hooked that up to the wrong wire. It should be your seat belt light that flashes
Old Oct 22, 2002 | 09:34 PM
KEVlN's Avatar
New User
Default Re: Stupid Question But I need an answer guys PLEASE!!!! (mr. skelly)
B16B_coupe
Sep 13, 2006 01:44 PM
aVstAr
Apr 24, 2006 02:58 PM
Got2HaveSol
Aug 28, 2005 03:59 PM
mikehawkBUiLT
18
Aug 22, 2004 07:24 PM
