90 honda accord brake problems
Old Apr 19, 2013 | 12:19 PM
Twiztd_Malk's Avatar
Default 90 honda accord brake problems
k, so I've got a 1990 honda accord, and I can put the brake pedal to the ground almost. And I'm not talking about "squishy spongey please bleed me" brakes, I'm talking smooth ride to a dead stop almost. I'm not losing any fluid anywhere, and when I step on the brake pedal I can hear a hissing sound. Took it to a local mechanic, and he looked it over and said it's probably my brake booster. I asked if it was the master cylinder, and he said more than likely no, since no fluid was being lost, etc etc. I was just wanting to get a second opinion...or 20, since ya gotta <3 the internetz, on whether it actually has a high possibility of being the booster before I run off to the junkyard to pick one up, since he barely took the time to give a decent one over?
Old Apr 19, 2013 | 06:01 PM
NvBiker1's Avatar
Default Re: 90 honda accord brake problems
Booster
Old Apr 19, 2013 | 07:02 PM
ReaperMan's Avatar
booster. that hissing sound you hear is a seal gone bad which is why the pedal goes down to the floor
Old Apr 21, 2013 | 07:29 AM
Lost Again's Avatar
Sorry, I vote master. They can and do fail internally meaning no leaking, just no pressure being applied to the calipers/wheel cyl.
The booster is a vac assist which make the force needed on the brake pedal less. Get the car in an empty parking lot, get it up to 20 mph, turn the key off - DON'T LOCK THE STEER WHEEL - apply the brakes. See how much more force is needed to stop the car.
Again just my vote.
Old Apr 21, 2013 | 07:43 AM
NvBiker1's Avatar
But master cylinders don't hiss !
Old Apr 21, 2013 | 04:07 PM
holmesnmanny's Avatar
Try bleeding the brakes first. That should be the first thing you should be doing assuming there are no leaks.
Old Apr 22, 2013 | 05:50 PM
Lost Again's Avatar
You are missing the point. You DO NOT need a brake booster for the car to stop and the brake pedal to remain at a "proper position". The main reason for the brake pedal to "sink" to the floor - air in the system, thanks holmes for asking the op to double check - is that the master is bad.
Think about it this way....your car will still turn even though the PS pump is bad............have a good day
laurentj23
Jan 28, 2012 06:55 AM
SikAuto
Jan 31, 2008 03:31 AM
slicermage
Aug 5, 2006 07:27 PM
CIVIC96DXcp
Apr 19, 2005 05:36 AM
wra10s
Aug 31, 2001 06:22 AM
