01 Prelude clutch.
Old Apr 19, 2013 | 10:08 AM
arrogantmeat's Avatar
Default 01 Prelude clutch.
My clutch has gone out in my Prelude. For now I switching back to a stock clutch, keeping my short throw, but I would like to get a stage 2, or maybe a 3 at some point. Could anyone give me a good site to get these parts from? I tried HondaAutomotiveParts, but I can't seem to find what Im looking for.
Old Apr 19, 2013 | 11:27 AM
h22god's Avatar
Default Re: 01 Prelude clutch.
http://www.competitionclutch.com/
Old Apr 20, 2013 | 07:54 AM
Geb8017's Avatar
Is your clutch making any noises since it gave out on you? I'm interested to know because my clutch had just gave out?
Old Apr 22, 2013 | 06:40 AM
h22god-thank you
Geb8017- No it didn't. I noticed that a few days before I would have to force the shifts instead of the gears just sliding into place. But now my clutch goes straight to the floor, and when I start it in gear it jumps like it wants to stall, but has just enough clutch to keep it goin.
Old Apr 22, 2013 | 08:37 AM
snobordboy's Avatar
Moderator
A bad clutch will generally be slipping when you apply power, especially in upper gears, as opposed to hard shifting. That sounds more like a leak in the system, either master or slave cylinder. Check your fluid level and look for leaks.
If it is a clutch issue, I would say a spring may have broken out of the disc, which will jam up between the disc and pressure plate, keeping the disc from engaging correctly.
I prefer Exedy clutches, and unless you are making 300+ HP, a stock replacement kit should be fine. I use a stock style Exedy on my car, and it has held up fine for 7+ years with 100s of drag passes between 4 different motor setups.
goodnacl
Jan 18, 2007 08:06 AM
h22_crx
Oct 16, 2005 07:35 PM
micmasta
Sep 7, 2004 04:08 AM
