Transmission & Drivetrain Gearboxes, Differentials, Clutches
Need help with release bearing
Old Apr 19, 2013 | 04:20 AM
89efhatchy's Avatar
Default Need help with release bearing
Here's the deal. I have a comp twin disc for 92-93 integra (8027-c), I've since parted the da out and decided to build a more streetable car out of my eg. The eg has a gsr trans in it. I know the disc from the 92-93 integra clutch will work with the 94+ hydro trans but what I'm worried about is will the release bearing from the 92-93 integra work as well?
Old Apr 19, 2013 | 06:27 AM
94EG8's Avatar
Seagull Management
Default Re: Need help with release bearing
No, you'll need a hydro release bearing.
Old Apr 19, 2013 | 07:48 AM
89efhatchy's Avatar
Okay, do you think an oem release bearing for a 99-00 si will work fine with the comp twin disc? I can pick one up locally versus trying to find and order the hydro release bearing from comp.
Old Apr 19, 2013 | 08:33 AM
94EG8's Avatar
Seagull Management
That I'm not sure about, can you compare the release bearing you have to an OEM/OE replacement release bearing for a '92 - '93 Integra? If they're the same then chances are an OEM release bearing will work.
I believe twin discs generally take a special release bearing though.
Old Apr 19, 2013 | 12:20 PM
89efhatchy's Avatar
I have an oem release bearing being delivered to the shop. I'll compare it to the release bearing that came with the comp clutch.
calebmeat
Jan 27, 2016 02:27 PM
Dubs13
Jul 16, 2009 06:57 AM
b18c eJ1
Mar 17, 2007 12:25 AM
integra4991
Mar 11, 2005 08:11 AM
The Toecutter
Apr 24, 2002 07:24 PM
