integra itr front clip shaved and tucked engine bay questions?????????
Hey everyone.... I got a 94 integra gsr...usdm with itr non hid front end conversion.I'm in the process of doing a wire tuck and abs delete....and had some questions .....so hopefully somebody can help....I want to make it look nice and be functional....I've already relocated the under hood fuse box to where the passenger side air bag used to be....battery is in the trunk......I have the wires for the headlights pulled through the door harness gromet on the passenger side.....I may have cut a couple of wires I needed for the coolant fan relay .....not sure though......can someone tell me how many wires I should have to run on the passenger side? Please help!!!!!! Thanks....
You should have 7,for high beam,low beam,parking light,turn signal,horn x2 wires and fan. If you have fog lights then there will be 8 wires in total on the pass side.
There's also an 8 pin rectangle shaped plug.....with 7 wires going to it....is that necessary? I wanna get rid of that too if possible..... plus the two relays....they have orange plugs......are for the abs?
How about the 8 pin rectangular plug?what's that for? Do I NEED it? They had it loomed up next to the radiator fan plug ... The wiring was really a mess on this car......lots of butt connectors......
