Factory Wiring Harness Repair
Old Apr 18, 2013 | 08:16 AM
dlewis2583's Avatar
Default Factory Wiring Harness Repair
Sup HT, Recently I was installing my new radio bezel and discovered upon reconnecting my cd player that it had no power. I came across the factory harness and notice a burnt wire (yellow, if it matters). as you can see its burnt all the way through. Can this be repaired and if so, how much am i looking at for running new wire?
Old Apr 18, 2013 | 09:32 AM
TheMuffinMan's Avatar
He knows where you live!
Default Re: Factory Wiring Harness Repair
My suggestion? Cut the wire then get comparable sized wire (from junkyard) and solder it in with heatshrink.
Old Apr 18, 2013 | 10:25 AM
dlewis2583's Avatar
Cool idea
Old Apr 18, 2013 | 11:01 AM
I did a similar 'fix' when I found someone had cut off the factory harness to install an aftermarket radio rather than spend $3 on an adapter harness. I went to the junkyard and resoldered ALL the connections to the radio. Worked like a champ.
Old Apr 22, 2013 | 05:38 AM
dlewis2583's Avatar
Salute to you bro! This the 3rd time youve come through! Much appreciated!
mad_ox1
Jul 25, 2015 12:27 PM
soNNy638
Audio / Security / Video
Mar 28, 2010 06:55 AM
MilesG
18
Dec 28, 2008 05:29 PM
'90crxSI
Sep 12, 2006 02:53 PM
Racermech
Jun 18, 2005 07:34 AM
