1990 Honda Accord AC bypass
Old Apr 16, 2013 | 05:23 AM
Twiztd_Malk's Avatar
Default 1990 Honda Accord AC bypass
Hi there, I've got a quick question. I've got a 1990 honda accord and the compressor is shot, the pulley is wobbling and you can hear a rubbing noise. I've heard that you can bypass the compressor just by getting the belt for the model that doesn't have AC, but I took it to my mechanic and he says that he needs to buy a bypass pulley for it. I'm kinda strapped for cash at the moment, so I'm just wondering if what he said was true, considering that every auto parts store I've looked at doesn't have a bypass pulley for a 1990 honda accord, and most bypass pulley's cost the same as a compressor that I can just pull from a local junkyard. I just can't find information on if I can just get a belt and take the compressor out of the loop, since I don't have the cash for the pulley or a compressor...thanks.
Old Apr 16, 2013 | 07:14 AM
Default Re: 1990 Honda Accord AC bypass
More to the point, can I just take a belt from a model that doesn't have a compressor and slap it on? I know you can on later models, since there's some posts here about like 95 accords, but I don't see anything about the 90 accords.
Old Apr 16, 2013 | 07:16 AM
NZXTInerTia's Avatar
90 accord motors are identical to all 90-2002 motors.
Old Apr 16, 2013 | 07:20 AM
thanks, I'm still learning the 'do it yourself" stuff, I knew 90-94's were identical, just didn't know they were identical to that extent. Gonna take it to another mechanic to have it looked at too, i'm starting to think that this guy has no idea what he's talking about....I've looked through all the auto part's stores I can find, and still have come up with nothing for a bypass pully on a 90 or later model, yet this guy quoted me at 100 dollars just for the part and said it was required to bypass it. Not to mention labor and a new belt.
Old Apr 16, 2013 | 09:06 AM
ReaperMan's Avatar
just go to autozone get a belt and tell them you don't have a/c and bam that is it
Old Apr 16, 2013 | 09:27 AM
NvBiker1's Avatar
I got a bypass pully on e-bay for 30.00 & uses
stock belt
Old Apr 16, 2013 | 09:57 AM
holmesnmanny's Avatar
You shouldn't need to change your pulley at all, just need a smaller belt.
Old Apr 20, 2013 | 09:52 AM
will I need to completely remove the compressor? Looks like it might be in the way of the belt, not 100% sure yet
Old Apr 21, 2013 | 02:27 PM
ReaperMan's Avatar
nope. no need to remove it. it JUST BARELY clears. never had issues on mine. you wasted $30 on a "bypass" pulley when a belt cost way less then that. they fooled you into thinking you need a "bypass" pully
Ruben Vela
Dec 17, 2025 06:27 AM
jenbirge
Dec 21, 2022 01:55 PM
Mike Beachy
Sep 28, 2019 12:15 PM
regina843
Jul 15, 2018 06:13 AM
James
Jun 23, 2004 06:30 AM
