TPS help!
Old Apr 15, 2013 | 05:21 PM
buster97's Avatar
Default TPS help!
so i have a funky idle when operation temp is fully warms up it bounces from 1250 rpm to 1050ish rpm and i covered the iavc hole in the TB(bottom hole) and nothing changed but when i cover the TPS hole?(top hope) it drops down to 800 rpm and purrs but if i unplug the tps it idles at 2000 rpms does this mean for sure its a bad sensor?
Old Apr 15, 2013 | 05:26 PM
stevenr2894's Avatar
Default Re: TPS help!
Have you adjusted your tps with a volt meter?
.5 @ ct 4.5-4.8 @ wot
Old Apr 15, 2013 | 06:14 PM
buster97's Avatar
Not yet I left my volt meter at work but I will
Old Apr 15, 2013 | 07:27 PM
Definitely do that. Set Ur wot using your hand turning the throttle. Set your ct by your idle screw. my car purrs at 900 with better response. I like my cable snug tight. Good luck
Old Apr 15, 2013 | 07:32 PM
B_Swapped93's Avatar
http://www.team-integra.net/forum/bl...peed-gen3.html
not enough slack on the cable is not a good thing either you'll notice evey time you'r TC sticks.
Old Apr 15, 2013 | 08:15 PM
No issues here. its snug, not to tight. works great. I like a touchy feel. just me
gabrielsousa
May 2, 2014 07:53 AM
asocallocal
Sep 23, 2010 06:20 PM
95civic16
Jul 20, 2008 05:44 PM
soHybridized
Mar 13, 2002 10:22 AM
John
Dec 10, 2001 06:51 AM
