megasquirt d16z6 HELP :(
Old Apr 15, 2013 | 03:13 AM
SpoonMotorSport's Avatar
Default megasquirt d16z6 HELP :(
hey all i am up on a project *Connecting megasquirt ms3x v3 mainboard on a usdm d16z6* i have done the wiring the car starts fine on stock p28 ecu but it wont start on the megasquirt the problem is with the megasquirt there is no spark whatsoever this is my first try on a standalone ecu! i am uploading pictures (the wiring connections and the Basemap setting plz guide me through)
thank you all i need to do this ASAP Pictures are as follows!
Old Apr 15, 2013 | 03:28 AM
Default Re: megasquirt d16z6 HELP :(
i have done the wiring as per above picture^^^^
Old Apr 17, 2013 | 01:05 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
i'll share a write up i found for OBD0 conversion, which you can use to help yourself with the wiring. what i have found when i attempted this, is that you need to play with the VR conditioning resistors for it to properly see the VR signal from the distributor, both the R52 and the R56 variable resistors. here is an article that can help.
good luck.
File Type: zip
Old Apr 17, 2013 | 09:12 PM
swordofdoom's Avatar
Hopefully you built the right circuit for the VR signal and did you use a jim stim to test it to see if it actually works?
Old Apr 19, 2013 | 05:49 AM
Jim stim?? circuit for the VR signal? all i did is connected the wiring made a harness for the v3 mainboard i didnt open the megasquirt what circuit you talking about? thanks
Old Apr 19, 2013 | 05:53 AM
good luck.
ok ill check the wiring! but i didnt get the VR conditioning thing where should i look for the vr conditioning? in the software? and can u share some details on how you connected your megasquirt to honda? the settings and all? thanx
Old Apr 19, 2013 | 10:12 PM
Where did you get your MS? The pots I mentioned are inside the unit. You will need to open it. I cannot share the settings with you since I have abandoned the idea of using it on my car for now. But read the file I had shared. There is a lot of info there. You can also go here for some info.
Old Apr 20, 2013 | 01:32 AM
Another one of those "I bought the damn thing and expect it to work" thread....
At this point I suggest you abandon the project and get a chipped ECU with datalogging or a s300. Less headaches involved.
Old Apr 20, 2013 | 02:22 AM
i expected it to work because i have paid 700$ anyways i thought it was plug and play i didnt expected such a reply on honda-tech anyways thanx for everything ill find my way out cheeers
Old Apr 20, 2013 | 08:48 AM
Have you looked at the links I gave you? Megasquirt is NOT a plug and play system.
Old Apr 20, 2013 | 12:03 PM
GhostAccord's Avatar
You need to set up the VR circuit on the circuit board for a magnetic VR sensor. These things are far from plug and play.
Did you put this together yourself or buy it assembled?
What version board do you have V3.0 or V3.57? They require different procedures.
All of the documentation is available on the DIYautotune.com forum.
Here is the VR setup page; http://www.msextra.com/doc/ms3/ignit...ml#vrv357logic
These document pages are now your Bible..... if you decide to stick with the MSIII EMS.
Old Apr 20, 2013 | 10:50 PM
i have read every single line on the diyauto tune before making a thread but i guess i have read the wrong part! i am using ms3x357 looks like 3.57 and i have done the wiring according to 3.0 let me overview everything again ill come back to you with step by step details what i have done! thnx
Old Apr 21, 2013 | 03:03 AM
i am using TDC sensor i have ignored the cyp and cam sensor
Old Apr 21, 2013 | 03:05 AM
the settings are as follows
Old Apr 21, 2013 | 03:07 AM
i turned the pot aswell! nothing happend! still no spark and no pulse to the injector!
Bryanstheguy2
Jul 15, 2011 06:39 AM
cleanbluef
Jun 1, 2007 01:19 AM
projsectEF
Jun 7, 2006 02:31 PM
D15Bbigred
Apr 25, 2006 04:36 PM
