Jdm F22b DOHC Head on F22a Engine
Old Apr 14, 2013 | 08:20 PM
Mishako129's Avatar
Default Jdm F22b DOHC Head on F22a Engine
Hey ya'll. I was wondering if putting the F22B jdm DOHC cylinder head would be a worthwhile swap to do on my 91 accord. They're the exact same size engines and I think it should give me some more get up.
Parts wouldn't be a problem either cause I know of many junked H23's preludes in my area with parts for the low low. There's an ECU for sale on ebay too... Thing is, I am having a hard time finding the cylinder head.
Has anyone done this or heard of people doing this?
Thanks.
Old Apr 14, 2013 | 09:01 PM
NZXTInerTia's Avatar
Default Re: Jdm F22b DOHC Head on F22a Engine
DO YOU FEEL THE NEED TO MAKE A NEW THREAD ABOUT EVERYTHING?
http://lmgtfy.com/?q=f22b+dohc+head+on+f22a
Old Apr 14, 2013 | 09:08 PM
Mishako129's Avatar
I did research it but only one person said it made better power. I need dyno graphs and better proof of it. Closest I came was this,
"This swap definately makes more power than the f22a6 with bolt ons. It is very close to the f22b, maybe makes less power due to less compression im guessing."
That was only from one person though, I need more people to tell me if this is a good idea.
Another reason I made this was to ask if anyone knew where to find the head at.
Old Apr 15, 2013 | 05:56 AM
nus_dogg's Avatar
It's been done. In fact, they've done it on a F22B2. Seen it online.
Old Apr 15, 2013 | 07:55 PM
Mishako129's Avatar
Is it a good idea? Thing is its harder than a **** to find them. Seems like a brilliant idea though. You could have the head milled to bump the compression to 9:3:1 and run the JDM ecu and have 30 or 40 more hp right there. Nobody ever posted any dyno graphs though, I looked everywhere.
Who wouldn't want to do that to their F22a, DOHC sounds awesome.
Old Apr 16, 2013 | 11:57 AM
Mishako129's Avatar
A guy on ebay has a F22b DOHC engine for sale for about $300 (with $125 shipping). He said its got bent valves though. I really only want the cylinder head. Do you think its worth buying entire engine with the bent valves for $425?
Old Apr 16, 2013 | 03:17 PM
GhostAccord's Avatar
Banned from CB7tuner again eh!
I imagine that it might be harder to find someone more tolerant of your ignorance and unwillingness to listen on here.
I wish you the best of luck finding someone to spoon feed you.
Old Apr 16, 2013 | 03:25 PM
ceejay77's Avatar
I have heard of this been done with good results my top end wearing out,if u do get it done let us know how it went and how much?
Old Apr 16, 2013 | 03:37 PM
Mishako129's Avatar
Ghost man, can you answer a quick question for me? Its about a 5 speed swap. I know of a couple of H23 preludes with 5 speed's but they got like 200,000 miles on them. Does a manual transmission need to be rebuilt if its got high miles on it?
I am making this thread to find out if this really is a good idea. I searched and seached but I only heard from 1 or 2 people on the CB7tuner forum say this made their car perform better but they never gave any videos or had it dyno'd to prove it. Everyone was saying "where are the dyno graphs?" but they never were given. Probably another reason why people don't do this swap often, other than the fact that F22B DOHC heads are rare.
Old Apr 16, 2013 | 05:21 PM
nus_dogg's Avatar
If you really want to, I see why not.
Old Apr 16, 2013 | 06:01 PM
Mishako129's Avatar
I don't understand this statement. Please elaborate for me bro.
Would head studs be a good idea if I am going to up the compression to 9:3:1?
Old Apr 16, 2013 | 07:21 PM
nus_dogg's Avatar
What I mean is that go for it if thats what you really want to do with your engine. As for head studs, are you talking about getting aftermarket such as ARP? or just doing stock replacement? I would do stock replacement as it's not needed; unless, you're going turbo or something.
Old Apr 16, 2013 | 07:29 PM
holmesnmanny's Avatar
The f22b dohc is almost the same engine as the h23. Your problem is your hindered by that auto. I would just ditch that and get a stick car.
Old Apr 16, 2013 | 07:47 PM
Mishako129's Avatar
I agree, but is it really that bad of a hinderance? I do want to swap it out, I found the nearest u pull it junkyard to me sells accords and prelude MT's for $90 a piece. All the shift cables and parts are just waiting for me to remove. I don't want to get it if its a worn transmission though. These have 150 to 200,000 miles on them.
It takes a lot of time to do this swap doesn't it? I can't do it if it takes more than a week. Seems like a pain in the *** to do though, gonna need an engine crane to support the engine with the transmission off, its gonna suck.
How difficult is this job? Personally I am a beginner but have already successfully completed an engine overhaul basically by myself...was a LOT of hard work though. 5 speed swaps seem complicated though and alien to me. I'm afraid that I'll get stuck somewhere.
Which guides do you recommend?
I found 2, the one with pictures is far mor valuable to me,
https://honda-tech.com/forums/honda-accord-1990-2002-2/5th-gen-auto-5speed-conversion-write-up-1235221/
http://www.cb7tuner.com/vbb/showthread.php?t=156847
Old Apr 16, 2013 | 07:54 PM
Mishako129's Avatar
I heard that the head is the same but the bore is 2 mm bigger in the H23. You wouldn't want to put an H23 head on an F22a block either.
.inbou
Oct 15, 2009 06:47 PM
K24.20A
Sep 29, 2007 10:32 AM
eightvalver
Apr 13, 2006 05:41 AM
honda_dude2004
Apr 12, 2004 09:52 AM
BurlyHatch
Feb 9, 2003 09:18 AM
