integra brake swap
would any of you guys reccomend swapping my 99 civic's rear drums with a 93 integra rear discs? Am I going to see a big difference, or should I just go with aftermarket frot discs and high performance pads? thanx for the help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MyFirstTuner »</TD></TR><TR><TD CLASS="quote">yes
yes they will...i did a rear disc conversion on my EJ8 and it helps alot during heavy traffic...
Just go with new front rotors + pads. Powerslot rotors with Hawk pads work nicely. You'll also want to bleed the system out and refill with DOT 4 synthetic fluid too.
I don't think the rear conversion is worth it. I found that the rear discs actually give you less stopping power than rear drums (when you pull the ebrake)
The only reason to do a rear disc conv is maintenance and looks, otherwise I think it's a waste of time and money.
eg686
21
Apr 4, 2005 05:07 PM
