blue top dsm 450cc injectors
Old Apr 13, 2013 | 04:56 PM
Eg.ls.turbo's Avatar
Default blue top dsm 450cc injectors
I've tested the ohms on these injectors and 3 injectors reads 1 ohm and 1 injector reads 2 ohms. Are the 3 injectors reading 1 ohm bad? I know they suppose to read 2-3 ohms. I've tried to search but couldn't find nothin.
Thanks in advance
Old Apr 14, 2013 | 10:19 AM
Default Re: blue top dsm 450cc injectors
Anybody?
Also wanted to know if I can use my rc 1000cc injectors from my turbo setup and use it on my all motor setup?
Motor setup
Gsr engine
Ls crank
Ls rods w/ arp rod bolts
Usdm type r pistons w/ Nippon rings
Stock yonaka head gasket
Golden eagle oil plugoff kit
Acl rod and main bearings
Super tech dual valve spring, keepers, and retainers
Skunk2 pro manni w/ hondata thermal gasket and bloc extended studs
2.5in yonaka series 2 headers
2.25in custom straight pipe w/ 4in hks tip
Accel 255cc injectors low impedance ( waiting to see if I can use my 1000cc injectors if possible)
Gsr tranny
Clutch master light weight flywheel
Act 4 puck sprung comp. Clutch
Stock gsr cams and cam gears
Ngk plugs and plug wires
Old Apr 14, 2013 | 08:48 PM
xile6's Avatar
Yea you can use the 1000cc injectors just tune for it.
And on the dsm I would try to ohm it again if not then it could be bad.
I never used the dsm ones tho because I didn't want someone's old and tried injectors. So I out for some rdx injectors.
Old Apr 14, 2013 | 10:42 PM
Ok. Thanks for the info. The dsm injectors I checked three times and still reading the same, guess they bad?
fitseries3
Dec 20, 2012 10:06 AM
jyracer
Nov 23, 2009 05:56 AM
thao0094
Jul 7, 2008 10:19 AM
Trajic
Aug 29, 2001 11:52 AM
