AC is not blowing cold anymore
Old Apr 12, 2013 | 02:20 PM
Mishako129's Avatar
Default AC is not blowing cold anymore
Hi guys. My AC won't blow cold anymore, neither will the fans turn on when I have the AC on. What can I do to fix this, can I please get some pointers?
Thanks.
Old Apr 12, 2013 | 03:04 PM
ReaperMan's Avatar
Default Re: AC is not blowing cold anymore
check fuses. send direct power to the fans to see if both fans run. if they do check relays. swap them out with known good ones. also jump the pressure switch that is on the driver side behind the headlight. you will see a aluminum cylinder type thing with thing pipes coming out of it. remove that plug and jump it if your ac turns on then you either have a leak somewhere of the ac pressure switch is bad
Old Apr 12, 2013 | 03:12 PM
ReaperMan's Avatar
ReaperMan's Avatar
<a href="http://s1346.photobucket.com/user/Wickedjb_xda/media/Untitled_zpsfa3a2bfb.png.html" target="_blank"><img src="http://i1346.photobucket.com/albums/p691/Wickedjb_xda/Untitled_zpsfa3a2bfb.png" border="0" alt=" photo Untitled_zpsfa3a2bfb.png"/></a>
Old Apr 12, 2013 | 03:16 PM
ReaperMan's Avatar
billtmore
Honda Fit
Jul 29, 2017 06:19 AM
Single-Cam
16
Feb 10, 2016 07:23 PM
KGNickl
May 1, 2008 01:59 PM
JasmitH
Jun 24, 2007 07:27 AM
