knock sensor
Old Apr 11, 2013 | 07:28 PM
BERT86's Avatar
Default knock sensor
How do you wire in a knock sensor
Old Apr 12, 2013 | 03:47 AM
holmesnmanny's Avatar
Default Re: knock sensor
you need to buy some 18 gauge shielded wire...attach it to a knock sensor connector on one end...to an ecu pin on the other...open up the back of the ecu connector and slide the ecu pin in...close the back of the ecu connector...peel back some of the metal sheath on the shielded wire on the ecu end...roll together enough of the metal sheath to put a butt connector on the metal of the sheath and put some wire on the other end of that butt connector and run that end to ground
Old Apr 20, 2013 | 03:37 PM
BERT86's Avatar
Ok thanks yo
BILLisCHILL
May 8, 2008 06:40 PM
bcphatchback
Dec 3, 2007 06:48 PM
jdmdseries
Nov 16, 2007 03:46 PM
nub_pwn
Nov 18, 2006 11:48 PM
