honde del sol no power to anything
Ok i have a 93 del sol sohc vtec but lastnight it rained and i guess caused a short since the car lowered and caused my battery to not hold charge. I figured bad battery went got it replaced still same issue so before buying a new alternator got it tested an it was fine. But here where inhave issue when i took it off it sparked i dont know if i caused short blew a fuse or what. Cuz went back to put it on hooked it all up now i dont have power to anything. Battery brand new and charged i check my fuses inside there ok i checked main fuse box under hood and i do get power to it. But when i check the fuses there with ignition on with a test light none of them light up ground ok im so lost what else can i do any help diagrams will help need my car its my daily driver
OK, believe it or not, you could have a very dirty battery terminal. Though they are often tight, they may lack a clean connection. Also, there are other fuse in the underhood relay center. There are probably 4-6 of them that screw down and are square. (not the usual sort that pull out) There is a large 60 or 80 amp (usually black) that protects the whole car. If you can not tell if it is blown then jump it with a pair of needle nose briefly to see if your car responds. Good luck.
I did what u said i jumped wired it and it worked fuse looked good to me but i was wrong now it works car runninv now it was 80a i went ahead changed terminal cable connector to be sure one wasnt tightnenin uo now im just hoping the shorts pops up cuz we checked it battery charging fine alternator fine idk what drawing power out of it n not letting it charge everything working the way supposed to
DelCarajo
25
Mar 19, 2015 12:05 PM
Hex420
Jul 24, 2007 02:06 PM
