Painting my trunk
Hey guys I never painted before and been reading around here for a bit. My trunk is green you see a lot of 96-98 civics have. Now I need to get it to my cars color code which is the taffeta white. Now I know I need to sand it down but how much sanding do I need to do?
I currently have these grit sand papers
-80 grit
-180 grit
-400 grit
Another thing I wanted to know is the taffeta white white they have at autozone any good? Does it completely match and would it be good to use it for painting the whole trunk? Also what would be a good primer to use.
-80 grit
-180 grit
-400 grit
Bought some SEM paint in taffeta white
after sanding and priming and sanding and 1 coat of SEM taffeta white paint so far
rattle can
Now it doesn't look the white i was expecting maybe after i do another 2 coats and clear would it look the same? Also after the first coat I see some drip spots can I wet sand it and paint over? If so what grit should I use?
rattle can
LEGiTLUDA
Dec 3, 2007 06:28 PM
Del Campo92
Feb 28, 2006 11:34 PM
