Spoon Throttlebody??
Old Oct 22, 2002 | 05:00 PM
SinisterCivic's Avatar
Default Spoon Throttlebody??
Im going to Japan in Jan fro the 2003 TAS and i was thinking bout getting a Spoon T/B. Its only US 173.00 so im gonna buy it either way...but my question for those who r running it, is it really a whole lot better...Like on Throttle response...and does the 70mm make that big of a differene?
Ferrell's Avatar
Default Re: Spoon Throttlebody?? (SinisterCivic)
not worth it
Old Oct 22, 2002 | 05:02 PM
Big Phat R's Avatar
It's just an OEM TB that has been taper bored to 70mm - the diameter of the plate at the butterfly is the same as OEM.
Old Oct 22, 2002 | 05:06 PM
Default Re: Spoon Throttlebody?? (Big Phat R)
Is there another T/B that is better or is the oem the best one for the R?
Old Oct 22, 2002 | 05:12 PM
Big Phat R's Avatar
It depends on the application.
For most - stock is fine.
Old Oct 22, 2002 | 05:13 PM
B2FiNiTY's Avatar
Stock is fine.
Old Oct 22, 2002 | 05:18 PM
Default Re: Spoon Throttlebody?? (ExOdy)
well im staying all motor so....
Old Oct 22, 2002 | 05:28 PM
neof69's Avatar
Mugen/King Motorsports offers porting your OEM TB 4mm over all the way through with a new throttle plate and reset the TPS for 150.00! This is what i am thinking about doing.
Old Oct 22, 2002 | 10:06 PM
AJ PwR's Avatar
Taper bore the exisiting TB you have. You will notice more mid-range gains.
Old Oct 22, 2002 | 10:17 PM
Jsracingintegra
Guest
Posts: n/a
Default Re: Spoon Throttlebody?? (neof69)
I dont see that on the web site.
Old Oct 22, 2002 | 10:22 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: Spoon Throttlebody?? (Jsracingintegra)
if you want 70mm i have a real 70mm BBK TB
Old Oct 22, 2002 | 10:34 PM
B2FiNiTY's Avatar
What does reseting the TPS do?
Old Oct 23, 2002 | 03:35 AM
neof69's Avatar
What i meant by reseting the TPS is they have to take it off in order to clean it and do what they have to do, and they just put it back on and "recalibrate" it to factory specs.
http://www.kingmotorsports.com/products/king/
[Modified by neof69, 12:36 PM 10/23/2002]
Old Oct 23, 2002 | 07:26 AM
Willard's Avatar
Default Re: Spoon Throttlebody?? (George Knighton)
Are any of the "not worth it" responses from people who have actually tried the Spoon throttle body?
dyno proven to make no extra power on a modified B18C5.
[Modified by Willard, 12:09 PM 10/23/2002]
Old Oct 23, 2002 | 10:00 AM
Revver's Avatar
not worth it. My buddy with a 98 Type-R put it on and ran slower. Trap speed stayed the same. It was identical 60 fts. and identical temp, humidity. That sealed the deal for me.
Old Oct 23, 2002 | 10:49 AM
Default Re: Spoon Throttlebody?? (Revver)
well that right there deff seals the deal for me...thanks for the info guys
Old Oct 23, 2002 | 11:28 AM
Dee Cee 2 R's Avatar
I have a Spoon TB
After my first tuning, I was rated at 175.4 at the wheels
Then I added a Spoon TB, I was rated at 175.7 baseline.
All I gain was 3 tenths of increase.
Keep in mind Their One year apart Exactly.
[Modified by Dee Cee 2 R, 10:12 PM 10/23/2002]
Old Oct 23, 2002 | 11:36 AM
Reid's Avatar
Global Moderator
Default Re: Spoon Throttlebody?? (Dee Cee 2 R)
The point of the Spoon throttlebody is to gain better throttle response.
No one ever claimed it would give you more power or decrease your ET's.
Does it increase throttle response?
Old Oct 23, 2002 | 11:39 AM
Default Re: Spoon Throttlebody?? (Reid)
honestly I believe it did.
The response is noticeable.
Overall I like it.
Old Oct 23, 2002 | 11:45 AM
Reid's Avatar
Global Moderator
Overall I like it.
If that's the case, then it does its job effectively.
If you cannot afford the downtime it would take to send your stock T/B away or you like to keep all of your parts stock in the event you ever sell the car, the Spoon throttle body is a worthy upgrade IMHO.
Old Oct 23, 2002 | 11:47 AM
B2FiNiTY's Avatar
I think it's a good upgrade for NON-ITR owners. Not exactly the most cost effective mod for the ITR.
Old Oct 23, 2002 | 11:52 AM
BERT-O's Avatar
nice pic there buddy
Old Oct 23, 2002 | 12:16 PM
SpoonCivic's Avatar
New User
I have it, noticed better throttle response, but on the dyno it netted miniscule gains (<1whp and <2lbs-ft of torque).
Old Oct 23, 2002 | 12:18 PM
maggsgsr's Avatar
Guys on a GSR they import tuner dynoed a JG throttle body on a 98 GSR and gained 6 WHP and 4lbs tq,do you think this is BS?
Old Oct 23, 2002 | 12:22 PM
BlueR's Avatar
