Honda CR-V & Element 2WD & 4WD Element & CR-V
knocking noise - rear drivetrain
Old Apr 10, 2013 | 05:01 PM
Deviant117's Avatar
Icon6 knocking noise - rear drivetrain
On the way home today doing about 65-70 mph I start to feel vibration. As I slow down I hear and slightly feel a quick steady knocking. Sounds like somebody knocking on a quarter panel. As I slow, the knocking slows, all the way to 5 mph. There is no knocking during heavy braking or heavy accelerating. Half shaft? U joint? Safe to drive 35 min to the dealer? I'm lost
Old Apr 10, 2013 | 06:58 PM
77777's Avatar
Default Re: knocking noise - rear drivetrain
i had this yesterday, tire blew out haha. its better now. get under there and inspect it, or i guess you could try to remove the shaft and drive around and see if it goes way. they say its easy to remove, i never have though.
Old Apr 11, 2013 | 05:08 AM
dogbiscuit's Avatar
if you remove the propeller shaft don't let the middle joint bend too much. also mark the housing and the shaft where they meet on both ends so you put it back on the same way you took it off.
Old Apr 11, 2013 | 06:28 AM
Deviant117's Avatar
And today the noise is gone... FML
Old Apr 11, 2013 | 01:16 PM
sliverSE.V's Avatar
^i like where you're going with your V
knelson
Jul 20, 2011 11:26 PM
motegicivic
Jul 13, 2011 03:42 PM
redm3turbo
12
Jun 11, 2011 04:35 AM
SilverDC4
Sep 20, 2005 08:11 AM
