Possible bad TPS ?
Old Apr 10, 2013 | 03:30 PM
Ej8_KiD's Avatar
Default Possible bad TPS ?
Ok guys the car is a 00 ex with a b18c and i was using a gsr throttle cable bracket and pulley , i replaced the throttle cable with a ITR cable and ITR cable stay and the according throttle cable pulley. now when the engine is running if i move the pulley with my hand or by pressing the gas pedal lightly it would get stuck at around 2.5k rpms and i have to give it a little tap so it can return to idle rpms again. but when the engine is not running it does not seem to stick.
I have cleaned the hell out of the throttle and iacv , lubed the return spring and still i have the same issue , so thats why im thinking its the tps.
Old Apr 10, 2013 | 03:35 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Possible bad TPS ?
So test it and stop worrying.
Old Apr 10, 2013 | 04:02 PM
S2BumpsticksGSR's Avatar
.48v idle and 4.5v wide open throttle(wot)is spec. A small diff in idle reading can make a large diff in idle speed. Phearable.net new tps $50- prob less on ebay...if you trust seller
Old Apr 10, 2013 | 09:32 PM
Ej8_KiD's Avatar
its reading .41 closed and 4.36 at WOT but i am not getting a cel either , could this be why the throttle is sticking while the engine is running?
Old Apr 11, 2013 | 05:47 AM
Ya, def possible. That's way off. Mine was about half as bad out of spec and had nice surging idle w/clean iacv. Recalibrated and TADA! Smooth operator now idle screw all way in 800rpm
Old Apr 11, 2013 | 05:58 AM
Ej8_KiD's Avatar
Weird , i still have the oem tps. I will try and get it back to specs and if not i might have to get a new one.
Old Apr 11, 2013 | 06:06 AM
Take off t/b and slot the snap off bolts so a screw driver can be used to remove them or just grind heads off/replace w/diff screws. Stock tps is adjustable.
Old Apr 11, 2013 | 11:38 AM
Ej8_KiD's Avatar
Calibrated the oem tps to 0.50v closed and 4.49v WOT and the throttle still sticks between 2-3k rpms. Any ideas guys? vacuum leak maybe?
Old Apr 11, 2013 | 04:41 PM
Ej8_KiD's Avatar
Anyone?
Old Apr 13, 2013 | 07:17 PM
Ej8_KiD's Avatar
bump for some answers
Old Apr 13, 2013 | 07:30 PM
You can verify a bad tps w/live data scanner. Watch your specific rpm problem range for erratic readings
bk7794
13
Jun 21, 2012 08:17 PM
cdmef
Jul 3, 2011 06:03 AM
bk7794
Apr 28, 2011 07:55 PM
dc2_dude
Jan 9, 2008 04:09 PM
integra99blue
Jul 16, 2001 07:56 PM
