Water Wetter?
Old Oct 22, 2002 | 04:32 PM
GZERO's Avatar
Default Water Wetter?
is this product any good? i've read tons of good things about it, and if you ask what about the freezing temps i don't get temperatures colder than 60 degrees, so, i don't need coolant, so i was thinking that the water wetter combination with water would work better and wouldn't make my engine die, what do you guys think?
i'm looking at experiences more than "i've heard" things
Old Oct 22, 2002 | 04:34 PM
Big Phat R's Avatar
Default Re: Water Wetter? (GZERO)
Good product.
I don't understand what you mean by "so i was thinking that the water wetter combination with water would work better and wouldn't make my engine die".
Old Oct 22, 2002 | 04:39 PM
GZERO's Avatar
Default Re: Water Wetter? (Big Phat R)
well, simply because water is the best to run on an engine because it absorbs heat better than any other liquid, but water rust metal, so if water is mixed with water wetter they say it doesn't create any rust because the water wetter has some lubricants that kill the rust properties of water.
(english is my third languaje) if you didn't understand i will try another way to explain it
Old Oct 22, 2002 | 05:06 PM
Big Phat R's Avatar
Yes but you are forgetting the fact that WATER BOILS AT 100 C. Adding coolant increased the boiling temperature. Water wetter is added to the water/coolant mixture.
read this:
http://www.redlineoil.com/redlineoil/wwti.htm
[Modified by Big Phat R, 6:08 PM 10/22/2002]
Old Oct 22, 2002 | 05:11 PM
GZERO's Avatar
yeah, but doesn't the radiator caps creates more pressure so that the boiling point of water would increase?
Old Oct 22, 2002 | 05:41 PM
91DA9's Avatar
yes it does, 28 mmHg raises the boiling point by 1 degree celsius.
Old Oct 22, 2002 | 06:22 PM
GZERO's Avatar
Default Re: Water Wetter? (94IntegraGSR-OVR)
so what would you guys recommend? as i say before the lowest temp i'm going to see with this car is around 65 F, the web page says that water with water wetter is the best combination. so i'm a lil confused
EDIT: by the way, the reading comfirms that is best to use water+water wetter
[Modified by GZERO, 7:59 PM 10/22/2002]
Old Oct 22, 2002 | 07:48 PM
PreIudeSI's Avatar
From: California ... Beauuutiful, so cal, pwnited States
for the record, water + metal doens't mean rust. Moisture and oxygen + metal = rust.
Old Oct 22, 2002 | 09:22 PM
GZERO's Avatar
so the answer would be?
Old Oct 22, 2002 | 09:23 PM
Big Phat R's Avatar
use glycol in your mix.
actual configuration of mix depends on operating/ambient temperature range.
Old Oct 23, 2002 | 08:42 AM
martini's Avatar
Default Re: Water Wetter? (texan)
I agree on the NPG+..
but I would suggest you use 10% anti-freeze in the mixture, for it's anti-corrosive properties, as well as to help lubricate the water pump.
Old Oct 23, 2002 | 12:30 PM
BROOD's Avatar
Water Wetter does nothing more than increase the surface tension of the cooling system fluid (strait water or antifreeze-water mix). Increased surface tension allows the fluid to stick to the walls longer thus increasing the heat transferred to the fluid and carried away.
It may have some additional additives for anti-corrosion but I'm gonna bet they are more of a marketing ploy than anything else. I use a small amount of dish soap.....it works the same.
**edit** I know this has been discussed before....try a search to see what you can drum up.
[Modified by SLPR, 1:32 PM 10/23/2002]
hondmywrld
May 9, 2007 12:35 AM
idriveadelsol7
Audio / Security / Video
Apr 10, 2006 12:30 AM
IMJUSTBORED
Oct 3, 2002 09:41 AM
Turbo00
Sep 13, 2001 11:06 PM
